Switch map on existing dashboard
23024
12
12-21-2017 11:18 AM
MikeOnzay
Is it possible to switch the data source of an existing dashboard from one hosted feature service to a different one without affecting the existing widgets? I created a hosted feature view off of a hosted feature service the dashboard uses. The only difference is that editing is not turned on the view.
jzcgis
Did you ever found out? I changed all the '#####-layer-#" thinking that would do it and changed the id for just the webmap but is there anything else to change? I still am not sure what the stuff before the # means.....it would be really helpful if ESRI would just have some simple explanations with these things....
josephgewin
In case others are still interested in this topic, I found this INCREDIBLY helpful!  I had a very complex dashboard with multiple elements that I wanted to redirect to a new WebMap and I was able to retain the integrity of all of my dashboard elements!
I simply went to this link https://ago-assistant.esri.com/ , found my dashboard that I wanted to redirect, did a web page search to locate the original WebMap ID, and replaced the ID with my new WebMap ID.  (just FYI, the WebMap ID is located at the end of the URL when you are viewing your WebMap.  It's the numeric code that's followed by "....webmap=")
Thanks to all who posted to help the greater GIS good!!!
Kevin_MacLeod
Decade later, still need this. And basics like this. More than 3D AR/VR/AI. I use Assistant and will use it for this, but a supported workflow to update the webmap would be great to see as an ENH.
