Short int issues in dashboards
580
10-13-2021 02:57 AM
mykola
Good day,
I am looking for a solution to the problem with short int fields in dashboards. Our data contains a lot of fields that were initially set to be short int. Recently, we started to use dashboards much more to visualize the data an ran into a problem. If the field is short int, it does not work well with selectors and serial charts. It results in 0 values in every second place/column/etc. I cannot find a way to get rid of it so if anyone has a solution I would highly appreciate it. One of the solutions may be to use Long int which behaves normally and does not produce such artifacts with zeros but this will only work with new datasets. We cannot change every single short int field in every feature class. Below is an example of how short int behaves in a serial chart and selector. Many thanks. 2021-10-13_09-45-52.png
