Popup and Details not in sync
870
03-10-2023 11:41 PM
RyanTucker
I have a dashboard where a map popup and details panel, which are pulling from the same feature, are displaying different results.
For some reason the results from a custom expression are missing from the map popup, but display correctly in a Details panel. This is triggered by a selection from a List.
Any ideas? I want to ditch the details panel. But can't do so until the popup works.
RyanTucker
Turns out the way I was calling the related table was incorrect.
ChristopherCounsell
MVP Frequent Contributor
Can you share the expression and how it's set up exactly?
Sounds like what you are doing is not supported (map pop-ups can't leverage the dashboards data expression, or the like)
Or maybe something like this:
https://support.esri.com/en/technical-article/000027068
If you can share more information or a sample map that would help a lot 🙂
RyanTucker
