Only display records with a value, hide Null values in a list
1304
07-20-2023 06:14 AM
dwold
I'd like to only display records that have a value, in this instance, a comment while hiding Null values in a list. Is there a way to do that with advanced formatting or another solution?
@jcarlson
@JohannesLindner
@JenniferAcunto
jcarlson
If the entire line of your List template is blank, it will omit the space entirely. The easiest way is to make the "Comments:" text part of the output itself.
var comments = Iif(
  IsEmpty($datapoint['Comments'],
  `Comments: ${$datapoint['Comments']}`
return {
  attributes: {
    comments
Then put {expression/comments} on its own line in the template. Should be what you want.
- Josh Carlson
Kendall County GIS
jcarlson
var comments = Iif(
return {
  attributes: {
    comments
- Josh Carlson
Kendall County GIS
dwold
@jcarlson thank you!
