Multiple Dashboards as Tabs in One Dashboard
7961
7
05-13-2022 09:37 AM
JorgeKappa
Is it possible to have multiple dashboards as tabs in one dashboard?
Different dashboards, different sources, different elements.
Dashboard showing three tabs, 1, 2 and 3, each showing dashboards 1, 2 and 3 respectively.
Is this doable?
TIA
jcarlson
You certainly could. Just build your three dashboards, then use the Embed widget in a fourth "container" dashboard and enter the URL to each of the three.
- Josh Carlson
Kendall County GIS
jcarlson
- Josh Carlson
Kendall County GIS
KhaterehAfshar
Hi, do you know how I can have access to Widget
BrianBaldwin
@JorgeKappa  Another idea could be tossing each of the dashboards into an Experience Builder application - you could then actually build '6' dashboards because you could have fullscreeen versions and then mobile optimized versions, but they would all be accessibly via the same 'application url' from the Experience Builder container.
Brian Baldwin, Esri Inc., Lead Solution Engineer
https://www.linkedin.com/in/baldwinbrian
PaulGiroux1
You could also use Experience Builder and leverage URL parameters in each dashboard to add filtered versions. Link from cards or top menu into the dashboard but specific to categories for example, Department, Maintenance Area, etc.
See details at - Configure actions on URL parameters—ArcGIS Dashboards | Documentation
jcarlson
Oh, yes. That's a really excellent idea. I wish it didn't constantly reload the embedded dashboard, but it still gives you some really neat options for a custom experience.
- Josh Carlson
Kendall County GIS
PaulGiroux1
I have a dashboard on a page and have the Embed "Auto refresh" off and it seems to do the trick.
JanetBrewster1
Paul,
When I try to embed an existing Dashboard, it says it wants me to sign in to AGOL. I don't understand...I am signed in -- the Experience and the Dashboard are both in my account. Any thoughts? Thank you!
