Latest Version & Proxy
4954
6
11-18-2013 05:34 AM
AdamRepsher
At the last version of OD, we could use a workaround to get through our company proxy server by editing the OperationsDashboard.exe.config file.  Simply change "false" to "true" in:
defaultProxy enabled="true"
This morning, I installed the latest version of OD and got this:
[ATTACH=CONFIG]29163[/ATTACH]
So, I uninstalled OD, following the multiple posts about properly deleting the contents of the "2.0" folder, and reinstalled OD.  I still get the same error: The remote server returned an error: (407) Proxy Authentication Required.  In checking the config file, the default Proxy setting is already enabled.
I have not been able to find any directions to login to OD, or for use with a proxy.
Could someone give me some help?
--Adam
CarolGhostine
Hi Adam,
I believe the line you changed previously to get through the proxy was; useDefaultCredentials="true".
Do you have a machine that is running 10.1.1.142 version of the Operations dashboard that still can get through your proxy server?
Have you tried to install the 10.2 version on another system that never had Operations Dashboard installed on it?
To get the ball rolling could you please log a support ticket and provide as much information regarding your environment.
Thanks
Carol
AdamRepsher
Yes, correct.  That is a part of the change that I missed, although I had to also change the other setting.  In the new version, both are set to true.
My machine running 10.1.1.142 was able to get through the proxy without issue minutes before I upgraded.  Another machine could do the same before upgrade (before I could stop him from upgrading).
No, I have not been able to do this.
I can log a support ticket.  Here is a little about our system....
We use a proxy called Bluecoat.
It uses authentication via Active Directory (AD).
We have AD Group Policies push out the proxy settings to desktops.
If the desktop does not have these settings, it will not be able to access the Internet.
If applications need to access the Internet and do not use the proxy settings, they will not work.
CarolGhostine
Thanks Adam. After you get the support number could you email it to me.
cghostine@esri.com
-Carol
JeffRyan3
Has there been any resolution to this issue?  I, too, am having the same problem even after re-installing Operations Dashboard.
CarolGhostine
Hi Jeff,
I would suggest anyone who is experiencing proxy issues with Dashboard please log a support ticket with as much details about your setup and network. This information will come into the correct channels of support so that we can start to address the issue.
Thanks
Carol
CarolGhostine
Hi All,
We have pushed an update to address the proxy issue today. Please see this link for details.
http://blogs.esri.com/esri/arcgis/2014/01/24/operations-dashboard-for-arcgis-10-2-update-1-released
Thanks
Carol
