how to solve can't access data
10948
12
07-08-2020 06:26 AM
mohammedalmaktoumi
hi,
I am facing " can't access data" when I try to create own dashboard.
regards,
blackhover
This Works When you hit the error for can't access data in the dashboard, what i found out was at some point when you share the data to the public it stops letting the dashboard see the information. After changing it back to the owner or org you can see it again but if you want to share it at any point you can't anymore. There may need to be a fix for this.
SimonSchütte_ct
MVP Regular Contributor
Here are a few possible solutions:
- Did you override your data source feature layer? When you have tables attached to it, check the table order. Assign layer IDs: https://pro.arcgis.com/en/pro-app/latest/help/sharing/overview/assign-layer-ids.htm#ESRI_SECTION1_11...
- If you use Views in an EGDB, Register the Views prior (!) adding the Tables to your Map in ArcGIS Pro for publishing or check the Data Source for your Layers to make sure the registered Geodatabase View is used and not the "normal" database view
- https://support.esri.com/en/technical-article/000023698
JoeStefanoni
I'm having the same issue with a data layer.  It displays fine in an Indicator and a Series Chart but when I select a subset through a category selector, the Indicator updates to the new grouping (in this case a county in New Jersey) but the Series Chart does not update and I get the cannot access data error.  I would think both items relying on this dataset wouldn't work but it's just the series chart.
