how to solve can't access data
10945
12
07-08-2020 06:26 AM
mohammedalmaktoumi
hi,
I am facing " can't access data" when I try to create own dashboard.
regards,
DerekLaw
Esri Esteemed Contributor
Hi Mohammed,
At which point in the authoring process of a dashboard do you see this message? When trying to configure an element in dashboard? Which element? FYI: in general, ArcGIS Dashboards supports feature and image layers,
Understand data sources—ArcGIS Dashboards | Documentation
Hope this helps,
mohammedalmaktoumi
Thank Derek for your quick replay,
actually, when I configure an element :
1- using statistics in any widgets for example ( feature or group values )
2- when I try to filter any widget using map extent it even sometime the layer not appear at even after remove the action.
appreciated your support.
DerekLaw
Hi Mohammed,
The error message you posted suggests that the data you want to use in the element is not supported or not accessible.
  • What kind of data are you trying to use? Please see the link I referenced previously.
  • Have you checked that you have access permissions to the data?
Hope this helps,
mohammedalmaktoumi
dear,
I think my issues in type of layer, could you please explain how can create feature service.
mohammedalmaktoumi
DerekLaw
Hi Mohammed,
Please review this help topic,
Feature layers—ArcGIS Online Help | Documentation
Hope this helps,
mohammedalmaktoumi
mdrivera
How did you solve this issue?
DIONYSIOSKERASIDIS
Hi guys
Although i had a very thorough research an a lot of forums no solution was found. After making my own research the problem seems to be ''data store'' and data communication especially if host your data on SDE drive. Easiest workaround is just RE SHARE  your service with no amendments on it.
