How to get list of keys from Arcade Dictionary
3764
01-18-2022 07:15 AM
DonMorrison1
I'm getting started with Arcade and can't figure out how to do something that I expect is quite simple. I have a function that returns a Dictionary object.  There is a special case that the caller has to process where the returned Dictionary is empty (ie. it has no keys).  How do I write that in Arcade?  I would think at least I could get an Array of keys then check the length, but I don't see how to do that either
var x = Dictionary ()
// My code here
if (??????(x)) {
    // Dict is empty!
else
    // Dict is not empty
Tags (1)
jcarlson
MVP Esteemed Contributor
It's not as straightforward as you'd hope for. IsEmpty is the go-to function for this for other objects, but a dictionary with no keys still returns a false.
There may be a better way to do this, but if you write an empty for-loop and then return the value of the loop's variable, and empty dictionary will leave it null.
var x = Dictionary()
for (var i in x){}
if(IsEmpty(i)){
    return 'Dictionary is empty!'
} else {
    return 'Dictionary is not empty!'
 And here's an expression to test it out:
function DictIsEmpty(dict){
    for (var i in dict){}
    if(IsEmpty(i)){
    } else {
var testDicts = [
    Dictionary(),
    Dictionary('key', 'value')
for (var d in testDicts){
    Console(DictIsEmpty(testDicts[d]))
Which prints to the console:
- Josh Carlson
Kendall County GIS
jcarlson
for (var i in x){}
if(IsEmpty(i)){
} else {
    if(IsEmpty(i)){
    } else {
var testDicts = [
    Dictionary(),
- Josh Carlson
Kendall County GIS
DonMorrison1
Thanks - this does indeed work - more elegantly than I was considering.  I've been working in Python exclusively for the past 5 years so it's hard to get  used to lots of loops and tricks like this again.
