How to extract values from an arcGIS dashboard
1332
01-07-2022 11:10 PM
Edward_Saif
Is it possible to scrape arcGIS dashboard data? For example. how would I scrape the number of cases for each country in Africa from the Africa CDC COVID-19 dashboard? I was at least able to find the JSON behind the map, but I'm not sure what to do next.
Thanks!
JayantaPoddar
MVP Alum
The Dashboard is using this feature layer DailyCOVIDDashboard_5July21_1
Its FeatureServer REST URL is https://services8.arcgis.com/vWozsma9VzGndzx7/arcgis/rest/services/DailyCOVIDDashboard_5July21_1/Fea...
You may add the REST URL to ArcGIS Pro. Then you could either convert its table to Excel sheet or to a new feature class.
Alternatively, you could query in the REST API https://services8.arcgis.com/vWozsma9VzGndzx7/ArcGIS/rest/services/DailyCOVIDDashboard_5July21_1/Fea...
Think Location
