Dynamic Dashboard/Automated Dashboard
6766
11
09-10-2021 10:11 AM
by Anonymous User
Not applicable
Hello, We are using Enterprise 10.8.1.  For dashboards we have created.  we want them to automatically/dynamically update.  We  connected our SQL server to ArcPRO and added the SQL data to the ArcGIS Datastore.  It is our understanding that the only way to dynamically update a dashboard is via the datastore.  This step is now complete.
We are now working on the analyst work flow in using the data.  I would like to know what the supported workflow is in using datastore data to create dashboards. This is what we have found. 1.  We usually bring in the data to ArcPRO, then display x,y to map points, then publish, then create dashboard.  2.  Now with the datastore, we followed the same process display x,y, create feature layer, publish to enterprise but when creating the dashboard and trying to create a serial chart we received an error that the data could not be used for statistics.   We discovered that using the tool Make Event Layer vs Display x, y when mapping the data worked.  In other words, we used Make Event Layer, published data, then created dashboard.  The serial widget worked with the data.  So my question is, is that how to create dynamic dashboards by using Make Event Layer, and you cannot use the display x,y to create a feature layer?  Thank you
by Anonymous User
Not applicable
We are federated, are you federated or stand-alone? It seems, but I am not 100% sure, that publishing a service works for stand-alone.   Thank you.
forestknutsen1
We are federated
