@jessneuner @Chris_Kell
Hi Guys - The work around I found was to go ahead and use 'Features' instead of 'Grouped values'. Of course, doing so will show all of the duplicates so I added a little extra context in 'List Item Template' to make it less obvious. In the Selector section, change Selection from Single to Multiple and make sure 'Show reset and select all' is enabled. Then, in the Actions section, you have the ability to link the related table to it's parent table for the map and other widgets on the dashboard.
On the Dashboard end, I show screenshots below where the user can type in 'warrant', click on 'select all', and as expected, it selects all warrants in the arrest category and displays only those on the map.
The downside, is that the user has to know what they are looking for. It's not as easy as selecting an item from a dropdown menu.
Also... if you do this, make sure to increase the 'Maximum Categories' to accommodate the number of records you may have. The default is 50.
Hope this helps a bit.
