Dashboard List Advanced Formatting
3005
06-10-2022 11:53 AM
by Anonymous User
Not applicable
In the list widget in the dashboard, I am just trying to change the letters from all uppercase to proper.  This is what I have so far, I am not sure how to get it to return though. Am I on the right track? Thank you.
prop = Proper($datapoint["Case_type"], 'everyword')
return {
textColor: '',
backgroundColor: '',
separatorColor:'',
selectionColor: '',
selectionTextColor: '',
//attributes: {)
// prop: prop
jcarlson
That first line would be var prop = ...
And then remove the // from the attributes area, since that makes them comments.
And then in your list, you'll actually reference the proper-case strings by using {expression/prop}, instead of {Case_type}.
- Josh Carlson
Kendall County GIS
jcarlson
- Josh Carlson
Kendall County GIS
