Dashboard- indicator currency units
7777
12
02-24-2019 06:35 PM
JosephJose
I have an indicator for a dashboard. The values store currency values
Is there a way to change the units, from number values like (K, M, G) to (K, Millions, Billion)?
StephenM
You can change number prefixes in the operations dashboard settings under the "General" tab.
Dashboard settings—Operations Dashboard for ArcGIS | ArcGIS
StephenM
JosephJose
why can't I see it?
Think it's a privilege issue. What privilege is needed for it?
StephenM
Are you the owner of the dashboard?
JosephJose
Yes
StephenM
If you're the owner of the dashboard I don't know why you wouldn't see those settings. What do you see if you click on the settings button?
JosephJose
The setting button isn't visible for me. Screenshot below
StephenM
That's odd. Maybe it has something to do with the version. Are you using ArcGIS Online or Enterprise?
JosephJose
Portal 10.5.1
Whom should I be approaching to rectify this?
StephenM
Ah, version is likely why that setting isn't available. The link I posted is for the web-based Operations Dashboard for ArcGIS Online and Enterprise 10.6+. The number prefixes setting was introduced last year:
Number Prefixes
The Indicator, Gauge, and Charting Dashboard elements support unit prefixing. Prefixing can be quite useful when indicating a multiple or fraction of a unit, such as “kilo” for thousand. Until now, Dashboard would simply apply the standard metric prefix symbol. However, with this update, when you access the Dashboard Settings, and click on the General tab, you can set the symbol used for the prefix. In the example below, you will see that the standard metric prefix for billion is G, for “giga”, but can be overridden to B for “billion”.
What’s New in Dashboard for ArcGIS (June 2018)
The blog post from when the new version of Operations Dashboard was introduced:
https://community.esri.com/community/gis/applications/operations-dashboard-for-arcgis/blog/2018/01/2...
The support page for the earlier version of Operations Dashboard:
Esri Support Operations Dashboard for ArcGIS 10.3.4
