Combine multiple values to color values using expressions
938
07-28-2021 11:18 AM
JoseBarrios1
Hello everyone,
I have a category field that I want to display on a dashboard list with different background colors (div) for each category.  For example: I have a field called “Project_status” and the categories are:
1.Completed,
2.Proposed,
3.In-progress,
4.Under-Review,
5.Funded,
6.Canceled,
7.Incomplete,
8. Extended,
9.Approved.
What I want to accomplish is to color “Completed”, “Canceled” and “Incomplete” with a GREEN background color, “In-progress” and “Under-Review” as ORANGE and else as GRAY background color.  I don’t want to create a new field just to combine the categories and I’m trying to build an expression to combine the values.  I was able to create an expression ( I'm just learning)  for coding a color for each category but I’m not sure how to ‘group” multiple categories to assign the same color code. Below is a sample of the expression I created. (I also created a HTML style using <div style="background-color: {expression/ backCardColor} </div> to assign the background color.) .   If you have any suggestions, please let me know. Thanks !
Var prjStatus= $datapoint["Project_Status"];
if (prjStatus == 'Under-Review') {  //... I need to add “In-progress” to have the same color.
return {
  backgroundColor: '',
  selectionTextColor: 'da687b',
  attributes: {
        backCardColor: '#f6deb1',
else (prjStatus == 'Completed') {    // I need to add “Canceled” and “Incomplete” to have the same color…
return {
  attributes: {
        backCardColor: '#dee7d5',
 else {
   return {
  attributes: {
    backCardColor: '#dfe1e3',
