Cannot Access Data with Gauge Element and Coded String
857
10-19-2021 12:43 PM
BrandonA_CDPH
I am working on a dashboard in ArcGIS Online.  I have a Feature Service that gets data from a Survey123 Form.  One of the questions is a select one question, so the field is a coded string. When I attempt to use it to filter data for a gauge (or other elements) on a Dashboard, the preview shows a yellow triangle and says "Cannot Access Data". The actual element in the dashboard just loads and loads with no end. When a use a different field in the same Feature Service (not a coded string), everything in the dashboard works as expected. This same thing happens when I use a View of the data or the data itself.
Is this a bug/limitation of the dashboard or something in my particular feature service? If it's a bug, does anyone have a workaround? The data is updated regularly and the dashboard needs to display the most current data, so something automated would be far preferred to a manual process.
Thanks in advance for any help.
