I am using Operations Dashboard for ArcGIS with AGOL. I am using a Side Panel element with Category Selectors and I would like my users to select an Agency to have all the District IDs, Status and notes to filter to that Agency that is selected. Currently, when I select an Agency it still shows all the District IDs when I just want it to filter to the specific Agency that is selected. I am not sure if this is possible but thought I would ask. Please see below:
Hi Jeremy,
You should be able to do this under the Actions tab of the Agency Category Selector. Set this to filter the other category selector. Ex:
Hi Jeremy,
That worked thank you Jake!
That's the problem I've got. I want to use the category filter and date filter on the top panel to filter all of the content on the page.
I think this is the same issue, but I don't get the option with the category selector.
I've tried it in Dashboard and Beta Dashboard - but I don't get the option to use the filter at the top on that element.
