Can you combine survey results via a grouped serial chart in ArcGIS Dashboards?
1090
08-09-2021 06:09 PM
by Anonymous User
Not applicable
I have two surveys which consists of several agree/disagree questions. They are the same questions, only one survey is a "before" survey and the other suvery is an "after" survey. Is there a way to create a grouped serial chart showing the before/and after as two different bars on the same chart?
I've attached an example. So the dark blue would be the results from the "before" survey and the light blue would be from the "after" survey.
Tags (1)
jcarlson
MVP Esteemed Contributor
Yes! But you'll need to use a Data Expression in order to bring in data from separate layers. The sample expressions can get you started, but you can find other examples on other Community posts if you look for them.
- Josh Carlson
Kendall County GIS
