Browser support for HTML Widget
3039
03-10-2014 12:37 PM
NicoleShi
When I add the HTML Widget (http://scheid.maps.arcgis.com/home/item.html?id=77022884dcb14cf3bc186a98b3f7aeb4) to my single display dashboard I get this error when I try to view it in a brower.
Operations Dashboard Error
Ember.Object.create only accepts objects.
6945d24eea944d6984f0718a6534d7bc
Is this Add-In just not supported in browsers? Is there another way to embed web pages into a dashboard where I can also view the dashboard in a browser?
Jon
AdamRepsher
It appears that only the widgets included in the base install of Windows OD are supported.  I tried a few other widgets yesterday with no luck.
--Adam
TifPun
Hi Jonathan,
We are planning to add support for addins in the web Dashboard in the future release, but as of now, they won't be working yet, that was likely the reason why you ran into an error when opening the operation view with an addin.
Tif
BrianBaldwin
It looks like this error is also raised when there are blank widgets.
Just something to note when folks are developing/testing web viewer Operations Dashboard templates.
Brian Baldwin, Esri Inc., Lead Solution Engineer
https://www.linkedin.com/in/baldwinbrian
