Unable to check "dynamic' when setting up a new operations view
2270
03-26-2014 04:53 PM
CarmaGerber
Hello
I am creating an Operations View using 2 feature services hosted in ArcGIS Online. The only option for settings in the Data Sources tab is 'Selectable'. There is no "Dynamic" option and data is set automatically to static.
Not sure what I am doing wrong here?
Thanks and regards,
CarmaGerber
Hello - I have solved this. The layer in the map needs to be set to refresh at a certain interval.
Carma
Kylie
by Esri Regular Contributor
Glad you got it working!
By default we honor the refresh interval set on layers in the map. You can override this and instead use a single refresh interval. Details can be found in Add a map and configure data sources step 6.
Esri Education Team
