Arcade Expression in Dashboard runs in testing, then Unable to execute Arcade script appears
11251
23
06-12-2024 11:29 AM
RichardCreek
Hello Community,
I am trying to determine why this arcade expression runs during testing, but then when I click "done" and go back to the "Select a layer" page to select the expression to use in a bar chart the data expression text is grayed out with an alert saying "Unable to execute Arcade script".
I've included my script below for reference, I would appreciate any assistance or explanation why this isn;t working as intended.
// sets portal url
var cobportal = Portal('https://bloomingtonin.maps.arcgis.com/');
// assign Crash Dataset variables
var crashDatasetID = '50b2634c8c9443f58cd004f1138ef7ea';var crashLayerID = 0;
// assign FeatureSet variables
var crashFs = FeatureSetByPortalItem(cobportal, crashDatasetID, crashLayerID, ['number_dead', 'gis_incapacitating'], true);
// Initialize counters
var totalDeaths = 0;var totalInjuries = 0;
// Iterate through the FeatureSet and calculate totals
for (var crash in crashFs) {
  if (IsEmpty(crash.number_dead) == false && crash.number_dead > 0) {
    totalDeaths += crash.number_dead;
    if (IsEmpty(crash.gis_incapacitating) == false && crash.gis_incapacitating == 'Yes') {
      totalInjuries += 1;
// Return the results as an array
return [totalDeaths, totalInjuries];
KenBuja
MVP Esteemed Contributor
I couldn't figure out a way to do that in the GroupBy statement alone, so give this a try where it creates new count fields for the two fields. I simplified it a bit so it wasn't writing all the attributes to the new FeatureSet, so see how it works.
// sets portal url
var crashFs = FeatureSetByPortalItem(cobportal, crashDatasetID, crashLayerID, ['number_dead', 'gis_incapacitating', 'collision_date'], true);
var fieldList = [];
Push(fieldList, {"alias":"Collision Year","editable":true,"length":4,"name":"collision_year","nullable":true,"type":"esriFieldTypeInteger"})
Push(fieldList, {"alias":"Fatal Total","editable":true,"length":4,"name":"fatal","nullable":true,"type":"esriFieldTypeInteger"})
Push(fieldList, {"alias":"Injury Total","editable":true,"length":4,"name":"injured","nullable":true,"type":"esriFieldTypeInteger"})
var temp_dict = {
  fields: fieldList,
  geometryType: '',
  features: []
for (var f in crashFs) {
  var attrs = {}
  attrs['fatal'] = iif(f.number_dead == 'Yes', 1, 0);
  attrs['injured'] = iif(f.gis_incapacitating == 'Yes', 1, 0);
  attrs['collision_year'] = Year(f['collision_date'])
  Push(
    temp_dict['features'],
    {attributes: attrs}
var newFS = FeatureSet(temp_dict);
var summaryFS = GroupBy(newFS, 'collision_year',
    {name: 'Total Deaths', expression: 'fatal', statistic: 'SUM' },
    {name: 'Total Injuries', expression: 'injured', statistic: 'SUM' }  ]);
return summaryFS;
RichardCreek
Produces this output:
Number of deaths should not be zero
KenBuja
I'm definitely not reading things closely enough! Just the injury field is Yes/No, so replace line 23 with
attrs['fatal'] = f.number_dead;
RichardCreek
Ken, you have been an amazing help, I really appreciate it.
