Arcade Expression in Dashboard runs in testing, then Unable to execute Arcade script appears
11223
23
06-12-2024 11:29 AM
RichardCreek
Hello Community,
I am trying to determine why this arcade expression runs during testing, but then when I click "done" and go back to the "Select a layer" page to select the expression to use in a bar chart the data expression text is grayed out with an alert saying "Unable to execute Arcade script".
I've included my script below for reference, I would appreciate any assistance or explanation why this isn;t working as intended.
// sets portal url
var cobportal = Portal('https://bloomingtonin.maps.arcgis.com/');
// assign Crash Dataset variables
var crashDatasetID = '50b2634c8c9443f58cd004f1138ef7ea';var crashLayerID = 0;
// assign FeatureSet variables
var crashFs = FeatureSetByPortalItem(cobportal, crashDatasetID, crashLayerID, ['number_dead', 'gis_incapacitating'], true);
// Initialize counters
var totalDeaths = 0;var totalInjuries = 0;
// Iterate through the FeatureSet and calculate totals
for (var crash in crashFs) {
  if (IsEmpty(crash.number_dead) == false && crash.number_dead > 0) {
    totalDeaths += crash.number_dead;
    if (IsEmpty(crash.gis_incapacitating) == false && crash.gis_incapacitating == 'Yes') {
      totalInjuries += 1;
// Return the results as an array
return [totalDeaths, totalInjuries];
KenBuja
MVP Esteemed Contributor
I couldn't figure out a way to do that in the GroupBy statement alone, so give this a try where it creates new count fields for the two fields. I simplified it a bit so it wasn't writing all the attributes to the new FeatureSet, so see how it works.
// sets portal url
var crashFs = FeatureSetByPortalItem(cobportal, crashDatasetID, crashLayerID, ['number_dead', 'gis_incapacitating', 'collision_date'], true);
var fieldList = [];
Push(fieldList, {"alias":"Collision Year","editable":true,"length":4,"name":"collision_year","nullable":true,"type":"esriFieldTypeInteger"})
Push(fieldList, {"alias":"Fatal Total","editable":true,"length":4,"name":"fatal","nullable":true,"type":"esriFieldTypeInteger"})
Push(fieldList, {"alias":"Injury Total","editable":true,"length":4,"name":"injured","nullable":true,"type":"esriFieldTypeInteger"})
var temp_dict = {
  fields: fieldList,
  geometryType: '',
  features: []
for (var f in crashFs) {
  var attrs = {}
  attrs['fatal'] = iif(f.number_dead == 'Yes', 1, 0);
  attrs['injured'] = iif(f.gis_incapacitating == 'Yes', 1, 0);
  attrs['collision_year'] = Year(f['collision_date'])
  Push(
    temp_dict['features'],
    {attributes: attrs}
var newFS = FeatureSet(temp_dict);
var summaryFS = GroupBy(newFS, 'collision_year',
    {name: 'Total Deaths', expression: 'fatal', statistic: 'SUM' },
    {name: 'Total Injuries', expression: 'injured', statistic: 'SUM' }  ]);
return summaryFS;
marksm_macomb
Dashboard data expressions require a featureset to be returned, but you are returning an array. You may want to create a featureset that has a category and a count field, and populate those fields with your totals. So I imagine you'll want to end up with a featureset "table" that looks like this in order to make a bar chart from it.
CategoryCount
Total Deaths###
Total Injuries###
Create a data expression—ArcGIS Dashboards | Documentation
KenBuja
A data expression must return a FeatureSet.
// sets portal url
      totalInjuries += 1;
// Return the results as a FeatureSet
var theDict = {
  'fields': [
    {'name':'TotalDeaths', 'type':'esriFieldTypeInteger'},
    {'name':'TotalInjuries', 'type':'esriFieldTypeInteger'}
  'geometryType': '',
  'features': [{
    'attributes': {
      'TotalDeaths': totalDeaths,
      'TotalInjuries': totalInjuries
return FeatureSet(theDict);
RichardCreek
I am pretty new to Arcade, how would you group the above output by year? I have a collision_date field where the year could be extracted.
KenBuja
You can do that with the GroupBy function. Esri has a GitHub site with data expression samples, with one on GroupBy.
You can add the year field to your FeatureSet using a modification of @jcarlson's Memorize function, then use GroupBy on it. This should work...but it's untested
**Edit...fixing field names. and more fixes
function Memorize(fs) {
  var fieldList = Schema(fs)['fields'];
  var temp_dict = {
    fields: fieldList,
    geometryType: '',
    features: []
  for (var f in fs) {
    var attrs = {}
    for (var attr in f) {
      attrs[attr] = f[attr]
    Push(
      {attributes: attrs}
  return FeatureSet(Text(temp_dict))
var newFS = Memorize(crashFs);
    {name: 'number_dead', expression: 'TotalDeaths', statistic: 'SUM' },
    {name: 'gis_incapacitating', expression: 'TotalInjuries', statistic: 'SUM' }
return summaryFS;
I was hoping to use an SQL expression to define the year from the collision-date field to avoid using the Memorize function, but I can never seem to get more complicated SQL expressions to work.
RichardCreek
I'm a little confused about the order of this expression, is this appended to the original expression or run by itself? It did not run in Dashboards on its own.
KenBuja
This is the whole expression. What do you get when you run in the code editor?
RichardCreek
Test execution error: Unexpected token ')'.. Verify test data.
KenBuja
I had to fix an error in line 13. There was an extra parenthesis at the end.
RichardCreek
Test execution error: Aggregation field not found. Verify test data.
