Arcade Data Expression Not Creating FeatureSet
2779
7
02-18-2025 11:16 AM
HaydenHarrison1
Hello,
I am trying to create a data expression that would query a feature layer containing work orders (WOs) and determine how many "outstanding" WOs (aka older than 7 days) we've had over the last 5 years. I am able to loop through the dataset and get a count of all outstanding work orders but can't get it to create a featureset to use in a chart widget on a dashboard. The output is a blank featureset. Version context: enterprise portal is on 11.1. Any input is greatly appreciated.
var workorders = FeatureSetByPortalItem(
    portal,
    'itemid',
    0,
    ['InitiateDate', 'ActualFinishDate', 'Priority', 'WorkOrderID', 'OBJECTID'],
    true
var filteredFeatures = [];
// Loop through work orders
for (var wo in workorders) {
    var startDate = wo["InitiateDate"];
    var endDate = wo["ActualFinishDate"];
    // Ensure both dates are not empty or null
    if (!IsEmpty(startDate) && !IsEmpty(endDate)) {
        // Calculate days to complete
        var daysToComplete = DateDiff(endDate, startDate, 'days');
        // Only include work orders that took more than 7 days
        if (daysToComplete > 7) {
            // Add the feature to the filtered list
            Push(filteredFeatures, {
                attributes: {
                    WorkOrderID: Text(wo["WorkOrderID"]),
                    InitiateDate: Date(startDate),
                    ActualFinishDate: Date(endDate),
                    DaysToComplete: daysToComplete
var finaltable = {
    fields: [
        {name: 'WorkOrderID', type: 'esriFieldTypeString'},
        {name: 'InitiateDate', type: 'esriFieldTypeDate'},
        {name: 'ActualFinishDate', type: 'esriFieldTypeDate'},
        {name: 'DaysToComplete', type: 'esriFieldTypeInteger'}
    geometryType: '',
    features: [
        {attributes: {
            InitiateDate: (startDate),
            ActualFinishDate: (endDate),
            DaysToComplete: (daysToComplete)
return FeatureSet(Text(finaltable))
KenBuja
MVP Esteemed Contributor
You're building the array of filterFeatures, but you don't add that to finalTable.
var finaltable = {
  fields: [
    { name: "WorkOrderID", type: "esriFieldTypeString" },
    { name: "InitiateDate", type: "esriFieldTypeDate" },
    { name: "ActualFinishDate", type: "esriFieldTypeDate" },
    { name: "DaysToComplete", type: "esriFieldTypeInteger" }
  geometryType: "",
  features: filteredFeatures
return FeatureSet(finaltable);
HaydenHarrison1
Hi Ken,
Thanks for responding. When I edited the code to your above suggestion, I got an invalid parameter error. ScreenshotParameterError.png
KenBuja
I ran your code using my own data and discovered that you have to convert daysToComplete to an integer (line 34). Otherwise, it ran correctly (with some field name changes and a different minimum days)
var workorders = Top(
    Portal("https://noaa.maps.arcgis.com/"),
    "b6b9dd55450a4f64bcafb3cd6e005a5c",
    0,
    ["stormdate", "surveydate", "efscale", "OBJECTID"],
    true
  10
  var startDate = wo["stormdate"];
  var endDate = wo["surveydate"];
    var daysToComplete = DateDiff(endDate, startDate, "days");
    if (daysToComplete > 2) {
      Push(
        filteredFeatures,
          attributes:
              WorkOrderID: Text(wo["efscale"]),
              DaysToComplete: Floor(daysToComplete)
var finaltable = {
  fields: [
      alias: "Work Order ID",
    { name: "InitiateDate", alias: "Initiate Date", type: "esriFieldTypeDate" },
      alias: "Actual Finish Date",
      alias: "Days To Complete",
  geometryType: "",
HaydenHarrison1
Changing the daystoComplete worked! I can now see the featureset. However, the date fields aren't populating. Thoughts?
    portal,
    'id',
    0,
    ['InitiateDate', 'ActualFinishDate', 'Priority', 'WorkOrderID', 'OBJECTID','DESCRIPTION'],
    false
// Debug: Check if workorders were retrieved
Console("Total Work Orders: " + Count(workorders));
    var startDate = Date(wo["InitiateDate"]);
    var endDate = Date(wo["ActualFinishDate"]);
    // Debug: Log first work order details
    if (Count(filteredFeatures) == 0) {
        Console("Sample Work Order: " + Text(wo));
    // Ensure both dates are valid
                attributes: {
                    WorkOrderID: Text(wo["WorkOrderID"]),  // Ensure it's string
                    DaysToComplete: Floor(daysToComplete),
                    OBJECTID: (wo["OBJECTID"]),
                    Description: (wo["DESCRIPTION"])
// Debug: Check how many were filtered
Console("Filtered Work Orders: " + Count(filteredFeatures));
return FeatureSet(Text({
    fields: [
        { name: "WorkOrderID", alias: "Work Order ID", type: "esriFieldTypeString" },
        { name: "startDate", alias: "Initiate Date", type: "esriFieldTypeDate" },
        { name: "endDate", alias: "Actual Finish Date", type: "esriFieldTypeDate" },
        { name: "daysToComplete", alias: "Days To Complete", type: "esriFieldTypeInteger" },
        { name: "Description", alias: "Description", type: "esriFieldTypeString" },
        { name: "OBJECTID", alias: "OBJECTID", type: "esriFieldTypeOID" },
    geometryType: "",
KenBuja
The field names in the dictionary ("startDate" and "endDate") are different than the attributes in the array ("InitiateDate" and "ActualFinishDate")
HaydenHarrison1
Unfortunately the feature set will not populate unless I use "startDate" and "endDate".
KenBuja
What I mean is that the attribute keys have to be the same as the Dictionary field names to be mapped properly
attributes: {
fields: [
  { name: "ActualFinishDate", alias: "Actual Finish Date", type: "esriFieldTypeDate" },
