Arcade Dashborad - Add new values into hosted table
2251
07-15-2021 09:51 PM
explocarto
For the purposes of a dashboard tool, I need to have a set of informations in a single table. To do this I try with Arcade queries to get my result.
Here is my table as a starter. (attachment 1.PNG)
One set of values per year and per type.
and this is what I'm looking for as a result (attachement2.PNG)
New fields with values already present in the table
I have tried a lot of things using dictionaries but without any convincing results.
Can someone help me?
jcarlson
You can't really have a true "table" in a Dashboard. You can have a table-like List element, but you'd need to calculate the new fields using a data expression, which I think is what you're attempting here, yes?
Can you share the code you've used so far and any errors you've gotten? That can be helpful.
Assuming you want a data expression, maybe something like this would work. It's hard to say sight unseen, and you'll probably need to tweak this to match your data, but it's a starting point at least.
var outDict = {
    'fields': [{'name':'Year', 'type':'esriFieldTypeInteger'},
               {'name':'Type', 'type':'esriFieldTypeString'},
               {'name':'ValueA', 'type':'esriFieldTypeInteger'},
               {'name':'ValueB', 'type':'esriFieldTypeInteger'},
               {'name':'YearPrev', 'type':'esriFieldTypeInteger'},],
    'geometryType': '',
    'features': []
var f_index = 0
var fs = FeatureSetBy // You can fill this in with however you're accessing your layer
for(var f in fs){
    var t = f.Type
    var y = f.Year - 1
    var prev = Filter(fs, 'Type = @t and Year = @y')
    var prev_a = ''
    var prev_b = ''
    // make sure your filter returned something, then replace prev values
    if(Count(prev) > 0){
        prev_a = First(prev)['ValueA']
        prev_b = First(prev)['ValueB']
    outDict.features[f_index] = {
        'attributes': {
            'Year': f['Year'],
            'Type': t,
            'ValueA': f['ValueA'],
            'ValueB': f['ValueB'],
            'PrevYear': y,
            'PrevValueA': prev_a,
            'PrevValueB': prev_b
     f_index++
- Josh Carlson
Kendall County GIS
jcarlson
var outDict = {
    'geometryType': '',
    'features': []
var f_index = 0
for(var f in fs){
    var t = f.Type
    var y = f.Year - 1
    var prev_a = ''
    var prev_b = ''
        'attributes': {
            'Year': f['Year'],
            'Type': t,
            'PrevYear': y,
     f_index++
- Josh Carlson
Kendall County GIS
explocarto
Hello Josh,
This is exactly what I need. I learned a lot from your code.
Thanks a lot !
Have a nice day
