Ability to format the search marker
266
03-17-2025 01:13 PM
Labels (2)
JayHodny
Hello, In ArcGIS Enterprise Dashboards, is there a way to format the web map search dot marker (also requested in How can i change the collor of Dashboards search r... - Esri Community).
 When I search for an address in a dashboard web map, the result is marked with a small dark dot, which is nearly impossible to see (somewhere inside the red circle drawn on the attached screenshot).  I can click the 'Zoom to' multiple times in the pop-up that opens, to zoom in to the location.  While this works, I was wondering if there was a way to make the marker larger, change color, have it flash, etc.  I have fiddled with the web map settings, point zoom scale, but I don't think I am configuring that setting correctly, i.e., not much of a zoom in to the address location is occurring.  Thoughts and help appreciated, many thanks.  Regards, Jay
Laura
by MVP Regular Contributor
Pretty sure I've seen a similar question in the EXB forums. I want to say over there they said you need to use the actual search widget, in EXB use case, for all of that configuration.
