ArcGIS Dashboards Questions
187
13.1M
2.7K
Open | We use a map with housing plans. It would be useful, for example, to add a climate risk map. Or a map with school fac... by LocatusAutomation New Contributor II 0 0 | 0 | 0 | |
Open | I wish text would automatically adjust or you could customize the font size when collapsed verses expanded. I set the... by VictoriaDavis1 New Contributor II 0 0 | 0 | 0 | |
Open | A basic principal of bar/column charts is that the y-axis should generally show zero. ArcGIS Dashboard allows a minim... by TimKuhn2 New Contributor II 0 0 | 0 | 0 | |
Open | The box for adding accessibility information is very small. I am writing a sentence and it only shows a 5-6 words, wh... by StevenTalbot New Contributor II 0 0 | 0 | 0 | |
Open | Please add support for the DateOnly field within Dashboards. Currently, fields of this type are not recognized when s... by TrevorGrayson1 New Contributor II 2 0 | 2 | 0 | |
Open | When hoovering over a dashboard element have the ability to have helper text describing detailed information about th... by StevenTalbot New Contributor II 2 0 | 2 | 0 | |
Open | When I create a new element in my testing dashboard, I can select a Data Expression from a list of existing expressio... by KenBuja ![]() 1 0 | 1 | 0 | |
Open | I'd like to see the option to add a refresh interval to data in List elements for Dashboards that are not part of any... by MtkaIraRaber New Contributor II 0 0 | 0 | 0 | |
Open | It would be nice if users could create a presentation quality report summarizing information based on a single featur... by clt_cabq Occasional Contributor III 4 0 | 4 | 0 | |
Open | It seems like such an easy win to enable user account and organisational details to be live inputs for dashboards.Thi... by RichardHowe Occasional Contributor III 4 1 | 4 | 1 | |
Under Consideration | In ArcGIS Dashboard on some of the elements you can activate the funktion "Summarized data download". This can be use... by AnnelieSköld New Contributor III 1 1 | 1 | 1 | |
Open | Our organization is using ArcGIS Enterprise with referenced SQL Server data stores in a federated Portal with ArcGIS ... by L_Hall New Contributor II 1 0 | 1 | 0 | |
Open | In Dashboard, it would be nice to alternate the row color of a list (not by condition). There have been cases where I... by KRankin New Contributor III 2 3 | 2 | 3 | |
Open | Please let us use a URL parameter to open a specific tab in our dashboard. Creating multiple dashboards and putting t... by ChelseaRozek ![]() 5 0 | 5 | 0 | |
Under Consideration | I’m hoping there could be an advancement to the Dashboard Serial Chart widget to add the ability to show a legend at ... by EllieLinden New Contributor III 1 1 | 1 | 1 |
Idea Submission Guidelines
User | Count |
3 | |
3 | |
3 | |
2 | |
2 |
