Use of related data in Collector for ArcGIS
1671
01-18-2018 12:37 PM
DavidHume
Hi all,
I'm trying to work out the best way to structure my data to allow our surveyors to capture data in the field with Collector.
They need to go out and survey trees and their defects. There is a many to one relationship between defects and the tree so I want to use related data so when they are in the field they can capture some overarching information about the tree, i.e. species, height, etc. and then for each defect they identify they'll then capture specific information. The information being captured for each defect is the same (same fields) but the type of defect will vary.
Can Collector use related data and how does this present itself to the surveyor, i.e. do they capture a point for the tree and then add tabular data for each of the defects?
Any help would be great.
David.
shan_sarkar
by Anonymous User
Not applicable
Yes - Collector could use related data. The trees will become a Point in collector and when you open the popup for the tree you could se/add/edit/delete the related defect/defects.
by Anonymous User
Not applicable
David,
This blog post will also be helpful.
Related Tables – Exploring New Ways to use Collector for ArcGIS | ArcGIS Blog
You will want to make sure your relationship classes are based on a GlobalID-GUID relationship since Collector will only be able to maintain those kinds of relationships
TiffanyRufo
David,
   We currently use this set-up for our city wide tree inventory. We have a point feature class representing each tree with data that is inherent to that tree (species, condition, size) and then a related table (one-to-many) for all of our maintenance records (trimmings, inspections ect.)
We have also managed a similar system with collector and Survey123 for our hydrants.
