Searching in Collector - No results found
6272
22
04-09-2014 09:55 AM
JasonHorning
I have a very basic ArcGIS Online Map that I am using with Collector.  When I download my map for use in Collector I attempt to search for attributes that are known to be available in the features within the extent I have downloaded.  I have yet to get a search result using even the most basic of information. Any help would be appreciated.
AmandaOpp
I have my search set up to look at a layer. I search for a location number of a pole in our system.  It still doesn't like it.   I started a group where I have shared the map that we are using in the field and have sent you an invite to join the group.  The group is called "FEC Answers Group".  Any help is appreciated!  Thanks!
RussRoberts
Esri Notable Contributor
I will take a look at it and see what the issue is.
Cheers
Russ
RussRoberts
Amanda Opp‌ can you update the sharing on the services into that group?
Thanks!
Russ
AmandaOpp
Yes!  Sharing all layers and services as we speak.  Thanks.
RussRoberts
Hey Amanda,
I am able to reproduce the issue you are seeing with your services in the web map as well and it looks like an issue with the JSON that is being written out when the map is saved. Can you please keep the map and services around while the AGOL team looks into the issue. I will send you an update when the issue has been addressed.
Thanks
Russ
AmandaOpp
Hi Russ!
Thanks for looking at it!  I will definitely have the layers on my AGOL until the end of August.  Good Luck.
Amanda
AmandaOpp
Hey there Russ,
I was just wondering what you guys have found?  I tried searching again today and still have no search results.  Thank you for all your help. I appreciate it.
Amanda
RussRoberts
This will be fixed in the upcoming update to AGOL. Re-saving the map should pick up the fix after the update to online.
Russ
AmandaOpp
That is great news!  When is the next update?
RussRoberts
AGOL is planning for the release to go out this week. We will be doing a Collector iOS and Android update within the next couple of weeks as well.
