I have my search set up to look at a layer. I search for a location number of a pole in our system. It still doesn't like it. I started a group where I have shared the map that we are using in the field and have sent you an invite to join the group. The group is called "FEC Answers Group". Any help is appreciated! Thanks!
I will take a look at it and see what the issue is.
Cheers
Russ
Yes! Sharing all layers and services as we speak. Thanks.
Hey Amanda,
I am able to reproduce the issue you are seeing with your services in the web map as well and it looks like an issue with the JSON that is being written out when the map is saved. Can you please keep the map and services around while the AGOL team looks into the issue. I will send you an update when the issue has been addressed.
Russ
Hi Russ!
Thanks for looking at it! I will definitely have the layers on my AGOL until the end of August. Good Luck.
Amanda
Hey there Russ,
I was just wondering what you guys have found? I tried searching again today and still have no search results. Thank you for all your help. I appreciate it.
Amanda
This will be fixed in the upcoming update to AGOL. Re-saving the map should pick up the fix after the update to online.
Russ
That is great news! When is the next update?
AGOL is planning for the release to go out this week. We will be doing a Collector iOS and Android update within the next couple of weeks as well.
