Re: Copying existing asset or observation not working.
322
05-31-2019 03:47 AM
AmitGupta2
Hi Kylie,
I appreciate if give feedback on my below queries...
I'm designing and planning to use Collector for ArcGIS to collect defects/faults.
I created a point feature service and consumed in collector..
Issue:
- I'm unable to fetch/copy attribute information from polygon feature. I need to copy only few attribute information, and those information will be use as a reference ID for the defect in the point feature.
- I have list of multiple faults category and subtypes, eg: Fault-> subtype1-> subtype2-> subtype3. my requirement is if I select major fault category, then associated subtype1 should be listed in the next field and if I select subtype1 then subtype2 should be shorted accordingly and same with selection of subtype2.
- How to control basemap in collector for ArcGIS?, I need to turn off all default basemap except shared organization basemap.
- we have requirement to control attachments, not more than 4. means user cannot attached more than 4 pictures of defect. is there any way to control attachments in collector or from feature service?
Amit
