Default Map Extent is missing from new app
920
04-01-2019 03:14 AM
SunilTerkar
I just tested the "Collector for ArcGIS" for iOS (v 19.0.1). Though the UI is much changed as compare to newly renamed "Classic Collector", I found my favorite "Default Map Extent" was missing. Does anybody know where it has been moved?
Kylie
by Esri Regular Contributor
Hi Sunil - If you use the Overflow menu (...) at the top of the map you'll find a Bookmarks option. Tap it, and the "Default map extent" bookmark is included in there.
Esri Education Team
SunilTerkar
Thanks Kylie. Never though it will be moved under bookmark. Easy to miss. I got it.
