Coordinate display/read out
6610
9
04-09-2014 05:43 AM
timburley
Hi guys. Is there a way to have the map touch coordinates displayed in a projection other than geographic wgs84?
A national meters grid would ideal.
Thanks Tim
MiaogengZhang
Have you tried current version of Android Collector (10.3.3)? It should have this capability. If you are using iOS, you will get this capability in the coming version.
RussRoberts
Esri Notable Contributor
Currently there is no way to change the reverse geocode coordinates to go off of the basemap projection.
Russ
GISSupport3
Could there at least be an option to change the format of the Lat Long display or display all three (3) formats?
Ideally would also have local projected co-ordinates.
timburley
Hi Russ
Can I upload a basemap in a projected coordinate system and have portal keep it in that system?
This should allow collector to work in the same system?
Thanks
Tim
RussRoberts
The app will not alter the basemaps projection but the XY you see displayed will still be in the lat lon for WGS84.
Russ
GideonSimons
Hi Russell,
Any idea when this will be solved as it works in WebApp - I have surveyors that need to jot coords down on crib sheet for specific surveys.
Thanks
Gideon
MiaogengZhang
GideonSimons
Hi , thanks - I am having problems with refresh on Collector so it did not appear to be working. Now it is fine.
JamesPreston
Hi Russell - is this still the case?
Marcos_AlmirOliveira
Hi guys.
Is there a way to have the map coordinates in "Collector" displayed and registred in a projection other than geographic wgs84?
I need the coordinates and attributes are displayed and recorded in UTM projection. How should I proceed?
Thank you,
Marcos Almir
