Collector app: Is there a way to make a field value default to the value in the previous record when setting up the DGB?
1265
12-12-2016 06:41 AM
BrittanyBankovich
For example, if a field tech is monitoring the same animal over a time-series can the field default to the same animal ID as the previous record?
GISSupport3
There is a Collection Style setting called Continuous.
This may assist you.
There is also https://survey123.arcgis.com/
