Collector for Arc on a windows phone
2745
09-23-2015 11:04 PM
MartyRocks1
Hi folks, I've created a map on ArcGIS Online for one of my field agents to use when out on site. He wants to assess and record damage locations and needs to be able to create point features when on site.
The data capture functionality works fine on iOS and android, however, when using a windows phone (Nokia) once he's created a point and entered in and saved attribute data, he is then unable to interrogate this data. On iOS or android, if you tap on a previously created point, a pop up window will display with any data you've entered about that point, however with the windows phone, when he taps on the point a pin appears on the map.
Has anyone else experienced a similar issue?
Cheers!
Tags (1)
RussRoberts
Esri Notable Contributor
Can you post this question in the Windows Collector beta group?
Collector for ArcGIS (Windows) Beta Program
Thanks!
Russ
