Collector App Update
4877
10
03-06-2013 08:21 AM
RussRoberts
Esri Notable Contributor
The Collector app has been updated on iOS and Android.
Whats new?
-Open maps by signing in using your ArcGIS Online account
-In-app search for your maps
-More sample maps under the Try Collector
Check out the blog post here:
http://blogs.esri.com/esri/arcgis/2013/03/05/collector-for-arcgis-and-operations-dashboard-updated/
Check out the Collector resources page here:
http://resources.arcgis.com/en/collector/
Cheers
Russ
NathanSommers
Are there any plans in the works for allowing a user using the collector app to connect directly to maps published via an in house ArcGIS Server as opposed to ArcGIS online subscriptions?
Thank you
RussRoberts
Currently the Collector apps will be supporting AGOL subscription accounts or Portal for ArcGIS accounts. Portal for ArcGIS would be your internal solution.
Here is some info on Portal for ArcGIS : http://www.esri.com/software/arcgis/portal-for-arcgis
Cheers
Russ
JasonBraunstein
Can you collect line and polygon features?
After you collect features can you export these features as a shapefile or into a geodatabase?
RussRoberts
The current version in the app store and play store today supports editing and collecting on a point feature service. The next release will have support for lines and polygons. The features are synced back with your ArcGIS Server feature service or Hosted feature service. We are working on an disconnected solution which will be in a future release but the next update will have tablet support, lines and polygon support and a few other enhancements.
Cheers
Russ
CameronWallace
Will the next version include offline capacity as well?
Also, when is it scheduled for release?
Thanks
luciobeltrami
Hello, I have a free arcgis.com account but I can't login with these credentials to the collector app: is it normal?
RussRoberts
Yes, the app works with AGOL Subscription accounts and Portal for ArcGIS accounts.
Russ
bbieb
Russ, when can we expect this release?
Thanks.
brian
brian
RussRoberts
The Collector app has been updated (v. 10.2) on iOS and Android (coming soon).
Whats new?
Updated user experience
Dedicated tablet and iPad experience
Support for collecting lines and polygons
GPS streaming
Improved collection workflows
Improvements to map tapping behavior
Various bug fixes and improvements
Support for enterprise logins
Support for additional languages
Android issues addressed: NIM090003, NIM090935, NIM091973, NIM092424, NIM092833
iOS issues addressed: NIM094438, NIM094401
