Cannot take Collector app maps offline
6311
16
12-08-2019 09:14 PM
SteveTaylor6
Collector app on all platforms has suddenly stopped letting you take a map off-line. This issue no doubt relates to the other issue I posted today about Collector app on-device edits on all platforms not syncing.  ArcGIS on-line and Collector app on-line still working.
Tags (1)
SteveTaylor6
Yes working again at 10:30am.  AEST.  It was not working since Saturday.
A better approach for esri would be if one of the techs had an on-device or off-line Collector map set up with scheduled syncing every 15 minutes (available on Collector Aurora on Apple) - so they could pick up these sync issues and quickly remedy them before disrupting customer work flows.
SteveTaylor6
Still not fixed. It is not resolved.
MiaogengZhang
Steve Taylor‌ can you share your hosted feature service URL? Are you at service1.arcgis.com?
SteveTaylor6
There was nothing wrong with our hosted feature service. This was an issue with esri’s services1. Syncing has now started working again. The problem started on Saturday.
ClayDonaldsonSWCA
We have a ticket open with ESRI tech support already. But I can confirm there are issues with https://services1.arcgis.com/
Would be great if someone at ESRI could change the status on ArcGIS Online Health Dashboard. As the issue is not resolved as of 2:00pm PT
MiaogengZhang
What is the support ticket number?
Can you confirm if both scenarios fails?
1) if you click sync with your existing offline data
2) download new offline area, do some edits and sync
From what I heard, for the job you submitted earlier today when the issues happen, it will appear hung.
ClayDonaldsonSWCA
Esri Case #02455643
Yes - both of those scenarios cause errors or will just be hung up indefinitely.
