Can I snap to existing data points when placing a new data point (manually) in Collector? Thanks
4328
07-07-2015 09:07 AM
ClairePook1
I would like to be able to create multiple new data entries at one location, and wonder if it's possible to be able to snap new data points onto existing ones? Perhaps there's a better way of going about this... Any suggestions welcome!
ScottPrindle
Hey Claire,
It is possible to copy the attributes and location, just the attributes, or just the location of a feature when editing in Collector. To do this, select the feature you're interested in copying and choose the context menu for that feature (in Android the gray arrow in the bottom-right corner). In the context menu, the option to Copy will let you choose from the three choices I listed above. This will work with the same feature layer, but will give you the ability to create coincident features.
-Scott
DerekLaw
Esri Esteemed Contributor
Hi Claire,
Please checkout the latest updates to Collector for ArcGIS (iOS), I believe it will meet your needs,
What’s New in Collector for ArcGIS (January 2020)
Hope this helps,
