HI,
I am having a problems with my attributes, sometimes the numbers look like that " 23.34" and sometimes like that "23.3400000000000000"
How can I set it only to 2 decimal places so all my attributes will look like that " 00.00"?
The attributes are the same in ArcMap, yet in CityEngine they are not
In the attribute "Height" one building is 23.43 and the other 23.9800000000000
Solved! Go to Solution.
No, there is not, currently.
Matt
If Matthias says it, it is truth!
Thanks you!!
Lukasz
Is it something that might be fixed later on?
Sincerely,
Lukasz
Hi ..
if you write a short specification on what precise behavior you need, we can send it to Zurich, to the dev team's wishlist.
Matt
Matthias Buehler
Head of 3D Technologies
twitter: @MattB3D
Garsdale Design Limited
Hi Matt,
The problem is in attributes and how the numbers are displayed in the WebScene, so for example it would be easier if I could specify the format of the numbers 0, 0.0, 0.00, 0.000, 0.0000, because right now some numbers look like that 34.00 and some 34.000000230123
Also, How do I hide the attributes?
@Hidden attr hide_me = 0 <---should It be above the "Lot-->" or below? and should I export it to attributes in order to make it work?
Sincerely,
Lukasz
