Parking lot and private street
4630
06-05-2015 01:23 PM
BrianLomas
Occasional Contributor III
I new to city engine so I apologize if this is an "easy question". I what to create a complex parking area that has private streets running throughout. Are there any rules that can acomplish this? Any help would be greatly appreciated, thanks.
Tags (1)
BlakeHarcourt
New Contributor II
It's going to a bit tricky but here is what i did quickly:
1. Create a road network and turn off block generation. Apply your road rule.
2. Create/import polygons for the car parks. Apply a rule to texture them.
3. Then create/import polygons for the dividers and areas between the car parks and the road.Then apply a rule to them to extrude them and texture them.
BlakeHarcourt
New Contributor II
BenLeslie1
I reckon you should be using the Sidewalk geometry as the parking spots.  Here's something very simple I knocked up in 2 mins - loads of potential to improve it....
attr valency = 3
attr type = "unknown"
attr spotWidth = 3
Sidewalk-->split(x){spotWidth:SplitGeom}*
SplitGeom-->
case valency < 3 || type == "unknown": NIL
else: ParkingSpot
Make sure you change valency and type to object defined attributes - have a look at these attributes in the objects hopefully you'll see what I'm getting at (I'm trying to exclude the bits of geometry that are too small/ too curved to be a parking spot) and be able to make improvements.  Also have a look as the 'Repeat Split' section in the help guide - you'll be able to make other improvements with that info.
