Object attribute overwriting
1443
12-20-2011 02:52 PM
timrobinson
Hi - I'm trying to use an object attribute sourced from the initial shape to drive calculations. The attribute is present in the script; when I select a shape and change the source of the attribute parameter to the shape, using the inspector, it overwrites the value attached to the initial shape....losing me the value!
Am I approaching this wrong? I've got it to work before, wondering if this is a glitch.....?
MatthiasBuehler1
hi Tim,
I tried, but sadly, I cannot reproduce the issue.
can you make a quick step by step list with a new scene & simple rule which let's me reproduce the issue ?
let me know ..
