Need to add delay before running ce.generateModels?
2437
04-10-2017 04:30 PM
RobertYu
Hello,
I am doing the following all in python:
  1. Associate a rule file with a shape
  2. Generate the model
  3. Create an new rule file
  4. Associate the new rule file with the shape
But when I try to regenerate the model using the new rule file, it seems to fail unless I put a delay in front, as in:
    time.sleep(10)
    shapes = ce.getObjectsFrom(ce.scene, ce.isShape)
    ce.generateModels(shapes)
Is there a reason why the delay is needed?  I might be doing something wrong here.
Robert
RobertYu
From trial and error, it looks like whenever you associate a .cga with a shape,
one should add a bit of delay to it, as in (function "framewait" defined in earlier post)
ruleFile = "rules/foo.cga"
ce.setAttribute(zone, "/ce/rule/ruleFile", ruleFile)
framewait(2)
LR
That's probably because CE is still busy with the first model generation. Try ce.waitForUIIdle().
RobertYu
Thanks for the suggestion.  I gave it a try it works a bit better.  I ended up doing a hack, where
I estimate the wait delay based on how many buildings (collada) I need to redraw.
def framewait(delay=0😞
    print "Waiting", delay, "seconds ..."
    time.sleep(delay)
    views = ce.getObjectsFrom(ce.get3DViews())
    views[0].frame()
    ce.waitForUIIdle()
    print "frame finished"
LR
Have you looked into  @noUIupdate and ce.generateModels ( --> asynchronous)? Those might help as well.
RobertYu
I upload the results to arcGIS online, so I do need the model to be complete.  With @noUIUpdate and asynchronous, how can I tell when the models are ready for upload?
RobertYu
framewait(2)
