How to use Text.cga in CityEngine 2014.0?
5471
13
08-26-2014 10:24 PM
AtsumiSOGAWA
In CityEngine 2014.0, there is text.cga in General folder in Esri.lib.
However, when I open it, there are some error in the rule file.
How can I fixt it and how to use the rule?
MatthiasBuehler
when you have started CE, click on the Esri.lib project and delete it (check the option delete sources on harddrive).
then just restart CE and it will recreate the default Esri.lib.
Ok ?
Matt
AtsumiSOGAWA
Thank you for the advice. I recreated the file, but the error messages still appears... two of my colleagues's machines also got the same errors.
TakCre
Hi !
I'm not sure but it seems that this issue comes from only Japanese platform since I can find the same message on my PC and another.
Thus I changed encode type to ISO-8859-1 on properties for text.cga .
Then no error massages and works fine!
Regards,
AtsumiSOGAWA
Thank you for the advice. It successfully worked!
