Getting the "last" split index of a rule
2134
02-16-2016 03:24 PM
LR
I'm dividing a building into horizontal slices and running an occlusion query, which colors the slices according to the touch results. I'd like to color the last slice touched in a different color. However, I can't figure out how to actually catch the last index. When I print the split.index the results are ordered in the console, suggesting that there does seem to be a way to catch the last split. Is it possible?
Rule:
version "2015.2"
attr SplitAccuracy = 10
attr BuildingHeight = 200
attr TouchColor = "#AAAAFF"
attr BuildingColor = "#AAFFAA"
attr LineColor = "#FFAAAA"
attr SplitCount = 0
@StartRule
Lot -->
  extrude(1)
  s(100,BuildingHeight,100) center (xz)
  SplitBuildings
SplitBuildings -->
  split(y){SplitAccuracy:CompBuildings}*
CompBuildings -->
  comp(f) {top : TouchCheck | side : Numbering}
Numbering -->
  set(SplitCount, split.index)
  texture("assets/no/no_"+SplitCount+".png")
  alignScopeToGeometry(zUp, 0, world.lowest)
  setupProjection(0, scope.xy, '1.0000, '1.0000)
  projectUV(0)
  TouchCheck
TouchCheck -->
  case touches(inter): TouchedRedlineCase
  else : NotTouched
TouchedRedlineCase -->
  #"case split.index == last split.index: LineColorColor"
  case split.index == 3 : LineColorColor
  else: TouchColorColor
NotTouched --> color(BuildingColor)
LineColorColor --> color(LineColor)
TouchColorColor --> color(TouchColor)
Result, with manual setting of the split index:
Tags (1)
by Anonymous User
Not applicable
split.total gives the total number of splits.
Chris
LR
Thanks, but I'm not looking for the entire split count, just the number of the last one that triggered the touch(). So split.index 3 in the example. Obviously I can't tell which number it is when I use the rule in multiple buildings with different elevation.. If I change the rule to this:
TouchCheck -->
  else : NotTouched
Touched -->
  print("Touched, "+split.index)
NotTouched -->
  print("NotTouched, "+split.index)
I get this ordered output:
Touched, 0
Touched, 1
Touched, 2
Touched, 3
NotTouched, 4
NotTouched, 5
NotTouched, 6
NotTouched, 7
NotTouched, 8
NotTouched, 9
so I thought maybe there's a way to catch that last "Touched" split.
