I'm trying to learn to use cityengine, but every time I try to download map data I get a gateway timeout error.
I sign in successfully, the get map data window pops up correctly, I set extent successfully and click okay. The progress bar appears and works through 'downloading elevation data', then stops at 'downloading map' around 1/3 of the way through, before throwing the error 'gateway timeout'.
I tried reinstalling, connecting through a VPN, restarting my PC, but nothing works.
Here's a screenshot of before the error appears, then the error itself:
Please let me know if there's a way to avoid this, hopefully it's just some small detail I missed.
Thanks! Changing both settings to 2k seems to be working consistently
This is still a problem 01/2023, I get "Read Time Out" errors when trying to download the smallest possible map tile in 4K. It will only download OSM data onto a 2K map. Is there a fix?IMG_5435.jpeg
Please Note: The solution only applies to CityEngine 2022.1
More details can be found here: CityEngine 2022.0 and earlier: Get Map Data textur... - Esri Community
Please excuse the inconvenience.
Did this ever get resolved? I am having this issue.
I have been getting this same error for the last 3 days, I decreased to 2k and still yet the error
Hi @CandiseBerard_SAIT We just tested it with 2k and we're not seeing the error. Is this still reproducible for you?
Thanks!
Dear team,
I am facing error with CityEngine when I try to download map with the "Get Map Data” command and when I select 4k resolution : it fail each time with the message “Gateway Time-out” .
It is working when resolution is set to 2K.
Can you assist me to fix this error please ?
CityEngine version 2022.0.8300 , Winx64 , 256Gb RAM
thanks
@TaishaFabricius The 4K gives the 'Gateway Time-out', the 2K no issues
