Generate power transmission lines and power poles
1118
07-15-2022 10:00 AM
RinuJoseph
Hello,
I am working on building a small part of a city. I was bale to bring buildings, trees and roads to cityengine and generated 3D models with rule packages. Now I am trying to visualize power transmission lines and power poles within city. I have the data from geodatabase and imported them as layers to cityengine scene. is there any rulepackages to generate poles and lines for this?
JonasObertuefer
I am not aware of any ready to use RPKs but why not write the CGA yourself? There is an older post in this forum with some guideance:
https://community.esri.com/t5/arcgis-pro-questions/powerline-rule/td-p/621334
Also checkout the Guideway rules here:
https://3dcitymodels.esri.ca/
And in ESRI.lib you can look at the rules in the Fences folder. Because powerlines are just big fences, right? 😉
Hope this helps,
Jonas
