City Engine CGA FIle Problem
1578
6
02-25-2014 07:56 PM
AmirSaleem
Hello everyone..
i need a help, i want to categorised some poles data and assigned them a specific pole shape in object, kindly tell help me.
one more thing any texture does not apply to the street network(Road).
Thank You
MatthiasBuehler1
Hi
1] Create the poles as separate asset files ( obj or dae ), add them to the assets folder.
2] Create a rule with the following code
3] Assign the rule to all imported pole position shapes ( originating from attributed point features )
poleFolder = "assets/poletypes/"
attr poleType = ""
attr poleRotation = 0
@StartRule
Pole -->
    alignScopeToAxes(y)
    s(0,0,0)
    i(poleFolder + poleType  + ".obj")
    r(scopeCenter, 0, poleRotation, 0)
    center(xz)
    Pole.
Let me know if this makes sense ..
Matt
AmirSaleem
Hi
attr poleType = ""
@StartRule
Pole -->
    alignScopeToAxes(y)
    s(0,0,0)
    center(xz)
    Pole.
Matt
Thank You soo much Matt, this code works but the alignment and location of pole object still not adjust, the pole become to much
large 😞
MatthiasBuehler1
Hi Amir,
then it's most possibly those 2 points :
1] make sure the pole size is modeled correctly and in meters
2] make sure the pole assets are modeled near the cartesian origin ( put the pole 'bottom' to 0,0,0 )
ok ?
matt
AmirSaleem
poleFolder = "assets/Poles/"
attr poleType = ""
@StartRule
Pole -->
    alignScopeToAxes(y)
    s(0,0,0)
    i(poleFolder + poleType  + "overheadpylon.obj")
    center(xz)
    Pole.
This is my code how can i control the shape and size of pole.
MatthiasBuehler1
The code
s(0,0,0)
i()
makes sure that the ORIGINAL size of the asset is taken. Since the scope size (0,0,0) is only a point, CGA falls back to the asset dimension when inserting the asset.
so you have to edit the 'overheadpylon.obj' asset in a 3d modeling application to give it the correct dimensions. Use e.g. Maya, Max, SketchUp or an other similar app.
Ok ?
m.
AmirSaleem
Thank You Matt for your lots of help. I try the 3D modelling software. i want to ask that there is no other option to solve this problem like we extrude the obj file with the attribute value????
