Multiple SketchUp buildings to Multipatch
3376
02-28-2014 08:53 AM
CarlBester
Hi All,
I have a question regarding SketchUp models.
I have received a sketchup model with multiple buildings of a new development. I want to export the SU model to CityEngine (in any format possible).
I have exported the SU model to collada, but all the buildings are represented as one feature, and I need a feature per building.
I then tried to convert the collada to a multipatch (from within CE). The result was a multiparch with one large multi-part feature (this is getting close to what I need but I still need to explode the multipatch).
Next I tried the GP tool "multipart to single part" to try and explode the multipatch to spatially seperated buildings. But the result was an empty multipatch feature class.
Is there a way to do this? Preferably a multipatch with each feature representing a building. But the same result in any format would be a great start. Is there any way of doing this?
Thanks in advance,
Carl
MatthiasBuehler1
Hi Carl,
In your case, just export 1 model pre building from SU. Import those files separately. Ok ?
If you have georeffed data, use kmls, drag-n-drop them in the CE viewport and you'll get a 'Static Model' per file.
just fyi : http://forums.arcgis.com/threads/68876-Importing-obj-dae-from-Sketchup
CarlBester
Hi Matt,
I have considered doing it this way, however there are too many individual buildings in the scene.
I have found a work-around (sort of). In SU I grouped the buildings according to precinct (approximately 5). I then selected the group and while making sure that the "Export Only Selection Set" is checked in the Export options, I  exported the group to a DAE file.
I imported this into CE. At this point all the buildings are still 1 feature and I could not move individual buildings. I selected the DAE feature and exported it to a multipatch.
After adding the multipatch I could move groups of buildings by selecting the correct edges and vertices manually. Although this is not ideal, it got the job done to a certain extent.
MatthiasBuehler1
Ok..
Maybe SketchUp lets you script this .. e.g. with Ruby script or so ..
matt
