Access scope of front side before comp split?
1989
04-24-2012 01:55 PM
MarieSaldana1
Hi Matthias!
I have a question that has to do with models built on sloped lots.
Following your example, I started with the base volume:
Lot -->
 alignScopeToAxes(y)
 LotAligned(scope.sy)
LotAligned(yDim) -->
 alignScopeToAxes(y)
 extrude(world.y, 100)
 split(y) {yDim : BaseVolume | ~1 : NIL}
Then I want to do something to the top only if the front face exceeds a certain y scope. But I don't know how to access the y scope of the just the front without doing a component split first, and then I can't apply this to the top face, which is already split off.
Any suggestions?
Thanks!
-Marie
PS. One related question: I was trying to deal with this by setting a boolean attribute, i.e:
BaseVolume-->
 comp(f) {front: BaseFacade | left : BaseSide | right : BaseSide| back : BaseSide | bottom : NIL | top : setPivot (yzx,4) Ground Row }
BaseFacade  -->
 case scope.sy >= floorHeight: set(multistory, true)
 else:  BaseSide
However, this doesn't work. Any ideas?
Thank you...
MatthiasBuehler1
hi ..
this is directly not possible, sadly.
maybe you can play additionally with geometry.lowerheight .. it may help you ?
[[ I think this is an undocumented geometric value. it's the height value of the lowest vertex of the extruded volume's top face ]]
Lot -->
extrude(world.y, 50)
split(y){geometry.lowerheight : X. | ~1 : NIL}
usually, the best strategy on sloped buildings is to decide if
1] all facades have synchronized floor levels. this is done by splitting the 3d volume into floor volumes, then comp(f) to get the facades.
2] all facades create independent floor levels. for this, you can comp(f) directly on the extruded volume.
I can post more later .. have a quick meeting now .. 😉
MarieSaldana1
Hey, thanks for the response.
I managed to work around it more or less but it would be immensely helpful to set an attribute for type:
attr multistory = false
BaseFacade  -->
 else:  BaseSide
I'm wondering why this doesn't work? I am able to set other attributes, like height.
Thanks!
M
MatthiasBuehler1
BaseFacade  -->
    case scope.sy >=
        floorHeight:
            Shape.
    else:
        BaseSide.
Try this, should work. (did not test the code). I assume you just need to define a Shape or NIL or something in the code.
MarieSaldana1
Hmm... that didn't work for me. Let me know if you think of something.
Thank you!
Marie
MatthiasBuehler1
maybe like so ?
attr floorHeight = 3
@Hidden
Lot -->
 alignScopeToAxes(y)
 alignScopeToAxes(y)
BaseVolume -->
 comp(f) {side : alignScopeToAxes(y) BaseFacade(scope.sy) | top : Top. | all : NIL }
BaseFacade(yDim) -->
    case yDim >=
        floorHeight:
            Printer
    else:
        Printer
Printer -->
 print (multistory)
