ArcGIS CityEngine Blog
Other Boards in This Place
Latest Activity
(76 Posts)
JenCE
by Esri Contributor
We are excited to share that this release has:
  • Python 3 integration introducing more possibilities for custom solutions and 2026.0 comes with three new out-of-the-box Examples to demonstrate relevant usecases:
Stylizing Scenes with a custom Python application using Generative AI
Use Python in ArcGIS CityEngine and import features from Overture Maps
Publishing custom metrics from ArcGIS CityEngine to ArcGIS Urban using Python
  • Streets with new clean-up tools and individual curb radii control
  • Visual CGA with a faster Node Browser and Previews
  • CGA with in-editor documentation, code completion and a refreshed reference
  • More out-of-the-box content to support your workflows
  • Streamlined Licensing
What's New article: https://www.esri.com/arcgis-blog/products/city-engine/3d-gis/whats-new-in-arcgis-cityengine-2026-0
Release Notes: https://doc.arcgis.com/en/cityengine/latest/whats-new/cityengine-release-notes.htm?rsource=https%3A%...
We welcome you to share your work and any questions you have in this community!
more
3 0 202
SimonHaegler
With a bit of delay we finally also announce the release of version 2.3.0 of ArcGIS CityEngine for Houdini!
Download the release from our Github page and see the manual for detailed installation instructions.
Notable changes include:
  • Updated Procedural Runtime (PRT) to 3.3.11669 (corresponds to CityEngine 2025.1).
  • Added support for Houdini 21.0.
  • Fixed crash triggered by empty CGA array attributes.
Please see the release notes for complete set of changes.
more
3 0 433
SimonHaegler
PyPRT 1.12 has been released! Please find information about what PyPRT is here.
The PyPRT packages are available on PyPI (https://pypi.org/project/pyprt) and on Anaconda Cloud (https://anaconda.org/esri/pyprt). Please see the README for installation instructions and example scripts.
Main changes compared to 1.11 (see changelog for all changes):
  • Added support for Rule Packages (RPK) created with ArcGIS CityEngine 2025.1.
  • Added support for Python 3.13, including pre-built wheels and conda packages.
more
2 0 328
SimonHaegler
We are happy to announce the release of version 1.4.0 of ArcGIS CityEngine for Rhino!
To get the latest release, please use the built-in Package Manager of Rhino (Tools -> Package Manager) and search for "CityEngine". Or download and run the installer manually. Please find detailed instructions the manual.
Notable changes compared to version 1.3 is support for Rule Packages (RPK) created with ArcGIS CityEngine 2025.0 and 2025.1, as well as a fix for a potential crash when using CGA array attributes.
more
2 0 340
SimonHaegler
Nvidia has announced that it will betransitioning Omniverse to a dedicated Developer SDK and is stopping development of connectors effective October 1st, 2025. In response to this change, Esri will also be retiring the Omniverse Connector integration in ArcGIS CityEngine.
ArcGIS CityEngine 2024.1 is the final release to support the Omniverse Connector (version 1.0.6). The Connector will no longer be available for download after October 1, 2025.
While the connector is being deprecated, the built-in USD exporter of ArcGIS CityEngine provides an alternative workflow to export city models to Omniverse. This is done by manually uploading your exported USD files to the Omniverse Nucleus server. This approach provides similar results to the connector, though without automated network transfer and live sync capabilities:
  1. Use the CityEngine "Universal Scene Description (USD)" exporter to write the desired scene to USD files.
  2. Use the Content Browser of an Omniverse-Kit Application (e.g. Composer) to open or upload the files to an Omniverse Nucleus server.
Additionally, we will also retire "Serlio", the CityEngine plugin for Autodesk Maya at the same date. Release 2.3.0 for CityEngine 2023.1 is the final release.
Serlio was originally developed for the M&E sector to help ingesting complex procedural building models into asset management systems. With the advent of USD (Universal Scene Description), this workflow is now considered obsolete.
We recommend users of the "Serlio" plugin to consider an USD based workflow:
  1. Use the CityEngine "Universal Scene Description (USD)" exporter to write the desired models to USD files.
  2. Use the Autodesk MayaUSD plugin to import the files into Autodesk Maya.
We will keep the corresponding github repository in read-only mode for future reference.
more
2 2 2,088
SimonHaegler
We are happy to announce the release of version 2.2.0 of ArcGIS CityEngine for Houdini (formerly known as Palladio)!
  • Updated Procedural Runtime (PRT) to 3.2.10650 (corresponds to CityEngine 2024.1).
  • Added support for Houdini 20.5.
  • Added support for polygon holes when converting Houdini geometry into PRT initial shapes.
  • Re-branding from "Palladio" to "ArcGIS CityEngine for Houdini".
more
3 0 753
SimonHaegler
We are happy to announce the release of PyPRT 1.11! Please find information about what PyPRT is here.
Main changes compared to 1.10 (see changelog for all changes):
  • Added support for Rule Packages (RPK) created with ArcGIS CityEngine 2024.1.
  • Added support for Python 3.12, including pre-built wheels and conda packages.
  • PyPRT and the underlying PRT library are now initialized and shutdown automatically.
more
2 0 737
SimonHaegler
We are happy to announce the release of version 1.3.0 of ArcGIS CityEngine for Rhino!
The one notable change compared to version 1.2 is support for Rule Packages (RPK) created with ArcGIS CityEngine 2024.1.
more
1 0 653
SimonHaegler
We are excited to announce the release of the Omniverse Connector 1.0.6 for CityEngine 2024.1!
Please download the installer from our github page: https://github.com/Esri/cityengine/releases/tag/omni-1.0.6
more
3 0 558
JenCE
by Esri Contributor
It’s always inspiring to see how the ArcGIS CityEngine community tackles real-world challenges. It is especially exciting when they share their work! In this new case study, learn how a team at UC Louvain in Brussels used CityEngine for a Python automated viewshed analysis to assess potential locations for Small Urban Wind Turbines (SUWTs) in downtown Brussels.
Read more...
more
2 0 757
126 Subscribers
