City Code
1885
01-25-2023 11:32 AM
lancelacourkatyedcorg
Where would you place the City Code so that I can pull the demographics of only the City.  They are not looking at surrounding area.
Thank you,
CherylHagevik
Hello @lancelacourkatyedcorg Thank you for reaching out with your question. To help us provide guidance, can you please tell us which Business Analyst application you are working with (i.e Pro, Web App, Experience Builder, etc.)?
JayLarsen
Hello.  I have the same question.  I have AGOL and BAO (web) and need to know the ESRI pop for city of Phoenix.  How do I get it? Is there an enrichment of some boundary by city from census and ESRI? Or is there a canned report in BAO?
FasilTiru
@JayLarsen
You have so many options to get demographic information for your sites. Simply start by defining the sites you need using this workflow:
After you define the Phoenix city boundary, you can use one of the available options here to get the demographic data in any format that works for you :
Fasil T.
JayLarsen
Thanks for the reply! That looks like a BAO workflow?
Which I figured might be a way to do it.  Since we do 90% of our work in AGOL, I wanted to keep it there.
It turns out the Living Atlas has a point layer and a boundary layer that work perfectly, containing the correct FIPS for the city of Phoenix in my case, so enrichment works properly.
My BAO skills are so rusty.  When we were new to ESRI we spent 90% of our time in BAO, not it's the reverse with AGOL since our skills have improved and allow for more detailed analysis and display.
Cheers!
